Date/Time: Wed, 25 Nov 2026 21:56:12 +0000
The SC trade copier
View Count: 603
| [2025-12-26 21:50:44] |
| User357195 - Posts: 204 |
I am using your trade copier for two accounts at one Prop firm and your the SC trade copier works great. My question is, if I have trading accounts at two different Prop firms, can I just add the 2nd Prop firms account numbers into one instance of SC or do I need to have two instances of SC running? For example, one for each Prop Firm and then enter the trading account numbers on one instance of SC for one firm and then have a 2nd instance of SC also running and add the accounts for that Prop firm on the 2nd instance of SC? Hope the above question makes sense. Let me know if I need to clarify anything. In my opinion, Sierra Charts are the best. |
| [2025-12-26 22:42:40] |
The "Order Allocation to Trade Accounts" only works within a single instance of Sierra Chart. There is no support across instances, which means that there is no support for copying trades to accounts at different firms, or accounts that are not part of the login that is used for that instance. We have heard of a few third party tools that can do this, but we do not know anything about them. We just want you to know you can look for them. -- In my opinion, Sierra Charts are the best.
Thank you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-27 00:43:03] |
So my choices would be to get a third party trade copier or run two instances of Sierra Charts at the same time. That would lead me to the next question...do i need a 2nd subscription for SC to run the 2nd instance or can I run two instances of SC on one subscription?
| [2025-12-27 05:17:56] |
| Sierra_Chart Engineering - Posts: 25483 |
You do not need a second subscription.
