Date/Time: Wed, 25 Nov 2026 21:56:12 +0000
Phantom window opening in 2nd chartbook
View Count: 406
[2025-12-26 19:02:41]
User719512 - Posts: 548
This is a strange one Sierra Chart Engineering team,
Present in v2840 and first noticed in v2842.
When I open a 2nd chart book, a phantom window opens with content from the first chart book (spanning multiple charts) and now represented as a window in chart book 2. I can resize this phantom window, and the contents of it never update (see attached).
This third window is not listed in the CW menu.
Not sure what other info I can give you on this, but can arrange for a demo or take a video for you if that helps.
EDIT: if I close the 1st chart book the phantom window goes away. So it's acting like a window always on top or always visible, but as you can see, there is no way this single window should be presenting content from 3 different charts from chartbook 1.
Date Time Of Last Edit: 2025-12-26 19:06:41
Private File
Private File
[2025-12-26 19:53:59]
We are making a note. This may be a case where, when a window is Hidden, when switching to a different Chartbook, the window hide for a chart is not actually being successful for some unknown reason.
[2025-12-27 06:10:39]
Saw you released v2843. I no longer see the issue reported above.
[2025-12-27 06:54:43]
This is good because we do not know the specific cause. Our explanation of the problem, in post #2, we are fairly sure is correct, but we do not know why that happens. But we did a thorough review of the code, and made some changes.
However, we are still concerned maybe the problem exists.
Do you have this option set to Yes in Global Settings >> General Settings:
Destroy Chart Windows When Hidden:
Date Time Of Last Edit: 2025-12-27 06:56:13
[2025-12-28 18:07:13]
That setting was set to No. Still fixed and "no repro" on v2845 either.
[2025-12-28 18:51:44]
This is good to know. Let us know if there is any further issue.
