Date/Time: Wed, 25 Nov 2026 21:56:17 +0000
Dom Graph
View Count: 434
[2025-12-24 12:35:02]
Pedro7 - Posts: 40
Hi, when using draw dom graph on chart the order/position lines overlap the dom graph lines so for that price level the market depth line is invisible. Is there any way to avoid this ? Can the colours of the dom graph lines be changed, where can i find it ?
Thx
[2025-12-26 15:48:50]
There is no way around this. The line associated with the order is always going to be displayed, and it will always be on top of the DOM Graph line. Changing the colors will not help this, although you can find the colors for the DOM Graph here (and the three settings below it):
Graphics Settings: DOM Graph Ask Lines Begin Color
We will note this as a Feature Request, but we would like to know what solution you would prefer. Some thoughts on our side (feel free to give another option if you have another way to do this):
- Stop the line that is drawn from the order before the DOM Graph.
- Mix the color of the order line with the DOM Graph, so when they are both at the same location you get a different color.
- Give an option to not display the line associated with orders/positions
[2025-12-26 17:55:47]
Pedro7 - Posts: 40
I would prefer that the order/position lines stop before the dom graph lines, same like the possibility you have with Chart-->Chart setting --> Trading --> Trade Drawing left align % but then instead of left the possibility to have it right. Or if you use lock fill space the order/position lines stops in the last bar.
Thx,
Date Time Of Last Edit: 2025-12-26 18:05:45
[2025-12-26 22:34:58]
Thank you for the information.
We have noted this as a Feature Request. We can not say when we would get to any particular request.
