Date/Time: Wed, 25 Nov 2026 21:56:18 +0000
Help
View Count: 403
| [2025-12-24 05:13:28] |
| seshohmaru - Posts: 9 |
I'm having a confusing problem regarding Data Limiting. I'm trying to load more data beyond a certain date, however, nothing works. I'll upload a screenshot but that doesn't fully show the problem. I'll change the settings on data limiting, or continuous contract data (futures), and click save, and nothing changes, and when I open the settings back up, none of the changes are shown. They're all gone, almost like I don't have permission to change them or something. I'm using SC data. Editing the dates does not help. |
| [2025-12-24 09:13:44] |
| User135243 - Posts: 337 |
Days to load intraday chart data is set to 60 and this is what you get
| [2025-12-24 21:34:32] |
| Sierra_Chart Engineering - Posts: 25483 |
One thing that we see is the chart, #9 (See the title bar), is being referenced by chart number #3. So chart #3 may be changing the settings back to match chart #3. First make the changes on chart #3. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
