Date/Time: Wed, 25 Nov 2026 21:56:19 +0000
market depth for cme exchange traded spreads
View Count: 628
| [2025-12-23 18:03:43] |
| User572630 - Posts: 1 |
I have the denali feed and the entire book showing in the outrights example LEG26 but when i do a exchange traded spread say LG26-LEJ26 it only shows 5 up 5 down bid ask levels is there a way to get the entire book for spreads? Thank you |
| [2025-12-24 03:33:23] |
| Sierra_Chart Engineering - Posts: 25483 |
If that is all you see, that is all there is regarding the number of market depth levels
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-24 03:33:33
