Date/Time: Wed, 25 Nov 2026 21:56:11 +0000
Large Volume Trade Indicator - Show only Bid or Ask Volume
View Count: 791
| [2025-12-22 15:49:15] |
| tdd2672 - Posts: 63 |
I am looking for a way to be able to show only BID or ASK volume with the Large Volume Trade Indicator. I use two charts one with Bid volume and one with Ask volume. I have changed the color of the Bid or Ask volume background to match the chart background on each chart. This works somewhat but it would be more ideal if there was a way to only show Bid or Ask volume. I've looked through the setting but have yet to find a satisfactory solution.
| [2025-12-22 17:56:22] |
The Large Volume Trade Indicator would need to be changed to have options for only Bid Trades and Ask Trades. We have set this as a Feature Request. We can not say when we would get to any particular request. We can not think of a workaround that will give you what you are wanting. You could create a custom study to do what you want. Refer to the following: ACSIL Interface Members - Variables and Arrays: sc.VolumeAtPriceForBars https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-22 18:58:03] |
This will be great if it can be implemented.
