Date/Time: Wed, 25 Nov 2026 21:56:23 +0000
Zooming out on Volume Profile
View Count: 334
[2025-12-22 12:36:13]
adams001 - Posts: 3
I recently made an update to my sierra chart and noticed that I can’t zoom out as much as I used to be able to on the sierra chart. I use it on Mac via Crossover and each time I use the down arrow button since the recent upgrade, the attached screenshot is how much I could zoom out by using the downward arrow button on Mac and this affects my analysis. I’d like someone to look into this and show me the right configuration
Private File
Private File
[2025-12-22 16:57:13]
You are going to be limited in the amount you can adjust the bar spacing at the point at which the data would be lost with any further modifications. This can be though of as the point at which the pixels are as packed as tightly as they can be.
The only "workaround" for this would be to increase the resolution of your display.
