Date/Time: Wed, 25 Nov 2026 21:56:13 +0000
future DTC protocol changes for fractional volume support
View Count: 428
[2025-12-21 11:44:56]
d9e5c763 - Posts: 112
Regarding the upcoming fractional volume support and internal move to double precision:
From the DTC side, how is this expected to be handled with respect to existing trade messages, specifically
MARKET_DATA_UPDATE_TRADE (double volume, timestamp truncated) and
MARKET_DATA_UPDATE_TRADE_WITH_UNBUNDLED_INDICATOR_2 (integer volume, higher-precision timestamp)?
Should DTC clients expect:
a new protocol version,
a new trade update message type, or
changes to one of the existing message definitions?
[2025-12-22 00:28:35]
seandunaway - Posts: 399
really not looking forward to the doubling of size on disk :(
(4 uint32, 4 floats to 8 doubles)
edit: and cache line misses
Date Time Of Last Edit: 2025-12-22 00:30:52
imagedata size.png / V - Attached On 2025-12-22 00:28:30 UTC - Size: 40.92 KB - 144 views
[2025-12-22 01:13:08]
There will need to be new DTC messages where necessary to support doubles for quantities/volumes.
In regards to post #2, where did we ever say, drive/disk space usage would be increased. That is not going to happen. There will be 0% change, with drive space usage.
Date Time Of Last Edit: 2025-12-22 01:14:15
[2025-12-22 04:55:44]
i'm sorry, i'm not that knowledgable about it. i assumed the s_IntradayRecord struct would change and be written out binary to scid
The Intraday data file format will also be adapted to support this.
Another critical thing related to the above, is that the internal storage of data within charts needs to go from 4 byte floats to 8 byte double precision floats.
Date Time Of Last Edit: 2025-12-22 04:58:22
[2025-12-22 05:29:55]
The volume fields within the Intraday data records written to files will not change in size but these fields will become 4 byte float values which is sufficient in 99% of the cases.
Date Time Of Last Edit: 2025-12-22 05:30:15
