Date/Time: Wed, 25 Nov 2026 21:56:18 +0000
Missing study value in Compact Tools Value window
View Count: 556
| [2025-12-19 22:36:04] |
| user 93611 - Posts: 6 |
I have an Average True Range study under a price graph window. I used to be able to see the value of the Average True Range of a bar when I hovered my pointer over the study below a particular bar. It would show in the Compact Tools Value window, instead of the OHLC information. I've been studying various tools to become better acquainted with the power of Sierra Chart, and somehow I must have clicked somewhere I shouldn't have because now I can no longer see the ATR value in the Compact Tools Value window. I have checked Study Settings -> Subgraphs and all the relevant boxes are checked (Display Name and Value in Chart Values Windows, Display Name and Value in Region Data Line, Display Input Values, Display Values When Hidden, and Always Show Name and Value Labels When Enabled). How did I lose that information, and how can I retrieve the value showing in the CTV window? I would like to know the exact ATR value for a particular bar when hovering over that bar in the ATR graph. |
| [2025-12-21 07:29:31] |
| Sierra_Chart Engineering - Posts: 25483 |
What Chart Region is the ATR in? It needs to be in a separate Chart Region other than 1, and then you will see it in the Compact Tool Values window when using the Chart Values tool and the pointer is within the chart region where it is contained in. We can see that is what you are actually describing: I would like to know the exact ATR value for a particular bar when hovering over that bar in the ATR graph.
So no need to answer the question.For now use the Tool Values Window: Window, CB and CW Menus: Tool Values Window (Window) Are there any other studies within the Chart Region where the ATR is? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-21 07:32:15
