Date/Time: Wed, 25 Nov 2026 22:21:10 +0000
Retracement tool
View Count: 493
| [2025-12-19 21:43:11] |
| cfuture - Posts: 86 |
I am trying to understand why the retracement tool has a change to the direction of the percentages when placing the target either to the left or to the right of the zero point. This makes no sense! I should not need four different retracement saved settings nor even two. I should only need one and whereever I place my initial point, zero point, then either above or below that level should determine the percentage extensions.
| [2025-12-19 21:55:12] |
| Sierra_Chart Engineering - Posts: 25484 |
It is the slope of the line, whether up sloping or down sloping which determines the origin point for the percentage calculations.
| [2025-12-21 00:29:01] |
Thank you but no matter the case, the initial point and positioning above or below that initial point level should determine the extensions.
| [2025-12-21 00:45:35] |
Check these settings in the Price Retracement Configuration: First Point Always 100 Percent: No Reverse Percentages: No Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-22 01:42:19] |
yes, that is what I have but when you move the target to the left or to the right, then that is what determines the direction of the extensions. I have been using negative numbers as a solution as well but thank you anyway.
| [2026-01-11 21:08:20] |
We will implement an option to disable using the slope of the line to determine, where the 0% level is for the Price Retracement tool.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-11 21:08:29
