Date/Time: Wed, 25 Nov 2026 21:56:11 +0000
Whether Teton Order Routing status affects DTC market data access (data-only usage).
View Count: 516
| [2025-12-19 15:06:34] |
| Vinay_Radhi - Posts: 3 |
Hi Sierra Chart Support Team, I am using Sierra Chart with the Denali Data Feed. I have enabled the DTC Server and am connecting via localhost (127.0.0.1:11099). My Python client successfully: - Connects to the DTC server - Sends EncodingRequest - Receives LogonResponse - Sends MarketDataRequest - Sends MarketDepthRequest However, I would like confirmation on the following: 1) Whether my Sierra Chart account and Denali Data Feed are fully enabled for: - Real-time Market Data via DTC - Real-time Market Depth (DOM) via DTC 2) Whether any additional settings are required in: - Global Settings → DTC Server - Data/Trade Service Settings - Symbol Settings for CBOT futures (e.g., YMH26-CBOT) 3) Whether Teton Order Routing status affects DTC market data access (data-only usage). My goal is to receive real-time tick and depth data via the DTC server (localhost) for external Python/C++ analysis. Thank you for your assistance. Vinayakumar |
| [2025-12-22 15:14:41] |
You can not get real-time data using DTC (or any other means). This is against the exchange regulations. Refer to the following: Data and Trading Communications (DTC) Protocol Server: Restrictions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
