Date/Time: Wed, 25 Nov 2026 21:56:14 +0000
Recent Bid/Ask clears early when using “Use As Trade Only Symbol
View Count: 571
[2025-12-19 10:06:45]
User500830 - Posts: 2
I’m noticing that the Recent Bid / Recent Ask columns in the DOM are being cleared sooner than expected when cross-trading is enabled.
Details:
* This occurs when Use As Trade Only Symbol is enabled for NQ/MNQ (or any other mini/micro) and used as a Trade and Current Quote Symbol.
* The clearing happens after a short time (exact duration seems setup-dependent).
* Disabling *Use As Trade Only Symbol* prevents the issue.
* Not using cumulative bid/ask columns.
Is this behavior expected when cross-trading is enabled?
If so, is there any way to extend how long recent bid/ask values persist in this configuration?
Without Use As Trade Only Symbol, disabled:
https://i.ibb.co/TqDzmdQh/2025-12-19-11-01-04.gif
With Use As Trade Only Symbol enabled:
https://i.ibb.co/dw3ZBjFk/2025-12-19-11-02-41.gif
As you can see, when cross-trading is enabled the recent bid/asks get cleared after x time as opposite as without it.
Thanks.
Date Time Of Last Edit: 2025-12-19 10:07:17
[2025-12-19 21:05:13]
Not sure about this. What is this particular setting for the chart set to:
Chart Settings: Clear Recent Bid Ask Volume Inactive Time in Milliseconds (Chart >> Chart Settings >> Market Depth menu)
[2025-12-20 08:58:26]
This is the current value for it: Clear Recent Bid Ask Volume Inactive Time in Milliseconds (0=disabled): 0
[2025-12-22 16:11:18]
Please check all the charts that you have that have the main symbol as NQ and see if that setting is set to a non-zero value in any of them. Any one of them having it set will cause this to occur in all charts.
