Date/Time: Wed, 25 Nov 2026 21:56:14 +0000
Stage 5 or Ironbeam account log in?
View Count: 850
| [2025-12-17 21:13:29] |
| lovelivelaught - Posts: 95 |
Hello I finally open an account with Stage 5 with Titon order routing. What a difference! compare to Rithmic I used before. I currently use Apex with Rithmic connection on my Sierra Chart. Anyway I was going though many youtube videos on how to set up Teton and Apex on Sierra and couple times I heard that I will need to log in, at least one a month to keep account active, I believe it would be the Stage 5 ( as they are my broker now) or Ironbeam where is my account? Because I actively using all services above, do I really need to log in in one of them? and which one? I just got confused here. Pleas any help will be appreciated! |
| [2025-12-17 21:30:52] |
If you are setup with Stage 5 and using the Teton Order Routing Service, then you do not need to worry about making the connection to your live trading account each month. -- Separately, we just want to make sure that if you are using both a Stage 5 and APEX account that you have separate installations of Sierra Chart for this. It is a lot easier to manage the separate accounts with separate installations, rather than constantly changing the Current Selected Service. Refer to the following for how to install an additional Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
