Date/Time: Wed, 25 Nov 2026 22:42:31 +0000
Number Bars (Footprint) Tick-by-Tick Historical Data Limits & Lookback Availability
View Count: 1699
[2025-12-17 12:56:43]
User877866 - Posts: 35
Hello Sierra Chart Support,
I’m looking for clarification on the limitations of Number Bars (Footprint) charts and the historical availability of tick-by-tick data, as I am attempting to analyze data going back to 2021.
Specifically, I’d like to understand:
Number Bars / Footprint Limitations
Are there any structural or performance limitations in Number Bars when loading very large historical ranges?
Is there a maximum number of ticks, days, or bars that can be loaded into a single Number Bars chart?
Are there recommended chart settings (e.g., Days to Load, Intraday Data Storage Time Unit, or replay vs live charts) to safely load multi-year tick data without truncation?
Historical Tick-by-Tick Data Availability
How many years back is true tick-by-tick intraday data available for US equities under:
Sierra Chart Exchange Data Feed
Denali Exchange Data Feed
Is 2021 tick-level data fully available, or does data prior to a certain year become compressed, aggregated, or unavailable?
Data Storage vs Feed Availability
If tick data exists historically, are there any local storage limitations or configuration requirements that could prevent older tick data from being downloaded or displayed?
Does Sierra Chart ever fall back to time-based or volume-based aggregation for older intraday data, even if Number Bars are enabled?
My goal is to run tick-by-tick footprint analysis (bid/ask volume, imbalances, and delta) consistently from 2021 onward, so I want to ensure I understand both data feed limitations and platform constraints before proceeding.
Thank you for the detailed clarification.
Best regards,
[2025-12-17 16:37:11]
No.
No.
No, as there is not an issue with the amount of data you want to load.
For data from Sierra Chart, refer to the following:
Sierra Chart Historical Data Service: What is Included
There is no Sierra Chart Exchange Data Feed, only the Denali Exchange Data Feed. Refer to the information given in the link about Historical Tick-by-Tick Data Availability
We do not know what you mean by this.
You need to ensure you have enough drive space for the data on your local system.
Refer to the information given above
[2025-12-20 16:11:50]
Okay, the reason I ask is because is when I go back on replay to review tick data in 2021 for these tickers below
AACG 2.4.21
OBLN 1.20.21
BBIG 1.21.21
the tick data either seems missing or all merged together on the Numbers Bar chart. I have included a screenshot of AACG on 2.4.21 as a example
imageAACG 2.4.21 intraday numbers bar footprint.jpg / V - Attached On 2025-12-20 16:11:37 UTC - Size: 166.13 KB - 248 views
[2025-12-20 23:03:52]
Sierra_Chart Engineering - Posts: 25484
For US equities, the data is compressed back at that time. It will be a 1 minute units.
[2025-12-21 13:03:35]
Thank you for the clarification. To confirm, for U.S. equities — at what exact date does Sierra Chart stop storing tick-by-tick data and begin compressing it into 1-minute units?
For example, is the retention window 3 months, 6 months, or 1 year?
I am trying to determine the earliest date at which true tick replay is available for small-cap equities.
Date Time Of Last Edit: 2025-12-21 13:05:39
[2025-12-22 16:26:51]
From the information in the link given previously:
At least 365 days of historical tick by tick data is provided for US stocks. Prior to this the US stock data is in 1 minute units and begins in 2008.
[2025-12-23 13:46:36]
Okay, and last question.
What if a stock does a reverse split split.
Does Sierra chart replay mode retain the PRESPLIT numbers bar/ tick data?
[2025-12-23 15:56:07]
The data is adjusted the evening after the split occurs so that the entire chart reflects the current pricing.
Replay does not have any specific implications with regards to splits.
[2026-01-29 15:13:15]
Is there any possible way to request or get the data uncompressed from 2021?
[2026-01-29 16:06:41]
For what historical data we have available, refer to the following:
