Date/Time: Wed, 25 Nov 2026 21:56:12 +0000
trade activity log only recording 1 day at a time
View Count: 489
| [2025-12-17 12:53:49] |
| User856350 - Posts: 46 |
can you help me figure out way my trade activity log is resetting and only recording 1 day at a time in sim trading i want the whole to track for example and i t keeps erasing and doing the day that i sim for example... even though i have my i have my display settings to record the whole month as i put the date nov 3 to end.
| [2025-12-17 15:52:59] |
| Sierra_Chart Engineering - Posts: 25483 |
Check this setting: Global Trade Settings Windows: Automatically Delete Trade Activity Log Files on Startup Older than Days (Global Settings >> General Trade Settings >> General >> Trade Activity) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-18 12:24:20] |
those are all fine so i should say that its not accumulating days so when i start and stop a day it resets and doesn't cautiously stack days like 30 days in a row so i can get a lump record log it rests and does only one day at a time when i stop the replay how do i change that to record until i manually reset it?
| [2025-12-18 16:23:38] |
If you are running a replay, then when the replay starts and you are prompted with what to do about the existing trading data, are you selecting the option for "Clear All Trade Data for Symbol and Account"? If so, then you are deleting all the trade data for that symbol and account, so any previous trades done would be deleted. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-18 18:08:46] |
yes i did do that one time but its ever since ive done that its deleted every day ive replayed... so i do 1 day of replay and stop and then want to do another day it delets what was there and starts again... im wondering how i can accumulate multiple days with it not deleting and starting over?
| [2025-12-18 20:25:06] |
What option do you select for what to do with the trading data when you start a replay?
| [2025-12-18 20:42:01] |
right now im selecting the accurate trading system back test mode
| [2025-12-18 20:47:21] |
When you start the replay, you are prompted about what to do about the Trade Data. In particular, you are given these three options: - Do Not Clear Trade Data for Symbol and Account - Clear All Trade Data for Symbol and Account - Clear Trade Data from Start Date-Time for Symbol and Account Which of these are you selecting? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-19 18:10:47] |
its never asked me that when ive done replays ive simply put in the day i want to replay it goes to that day and i just hit play. its never asked me these questions
| [2025-12-19 18:51:14] |
If you are not seeing the prompt described in post #8, then that is not the issue.
