Date/Time: Wed, 25 Nov 2026 21:56:22 +0000
ETH trade fills executed but not displayed on chart (no exit markers or trade lines)
View Count: 435
| [2025-12-17 11:25:25] |
| User700382 - Posts: 30 |
Hello, I am experiencing an issue with trade visualization in Sierra Chart. The situation is the following: Entry orders are displayed correctly on the chart during RTH session. Exit orders (sell-target orders in this case) executed during the ETH session are NOT displayed on the chart. There is no trade line connecting entry and exit. However, the trade was definitely executed: Account balance changed correctly Trade Activity Log doesn't shows the fill for some reason, despite balance change. What should I do for trave activity log to start showing this exit. Additionally, I would really appreciate if you could explain me the steps that are needed in order to create a chart of my trade balance during some time ( exemple I wanna see all the drawdowns and profits as candles on the chart during last half a year ). Thanks in advance! |
| [2025-12-17 16:31:25] |
Please exit from Sierra Chart and restart and see if that brings in the missing order fill. Let us know if it is still not showing after you do this. -- Additionally, I would really appreciate if you could explain me the steps that are needed in order to create a chart of my trade balance during some time ( exemple I wanna see all the drawdowns and profits as candles on the chart during last half a year ). There is not really a way to do this in Sierra Chart, at least not for more than a day. Refer to the following studies that can get you information for a day: Trading Information Windows: Trade Data Studies For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-17 16:40:25] |
No, when I restarted sierra chart nothing changed. But now I deleted trade activity entries so that they don't make a mess on the chart at this point. Not sure why it does so. It actually happened to me multiple times in the past, when I entered during RTH but exit was during ETH and it didn't show me no fills during ETH, plus trade activity log was showing only the entry with no exit that happened during ETH.
| [2025-12-17 18:38:11] |
Is this in a Sub-Instance or in the Main Instance? Make sure the Main Instance is showing everything properly. Keep in mind that you are using the Teton Order Routing Service, so even if you remove order fills from your Trade Activity Log, the next time you connect, those fills are going to repopulate the Trade Activity Log. If you do not want to see fills prior to a specific date-time in the chart, then refer to the following setting: Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
