Date/Time: Wed, 25 Nov 2026 21:56:20 +0000
Historical Data
View Count: 461
[2025-12-17 10:35:04]
Isma.Sesay - Posts: 11
is there any chance to have data of CL contracts before CLQ25??
Attached a screenshot of my actual situation
Thanks in advance
imagePic_3.png / V - Attached On 2025-12-17 10:34:51 UTC - Size: 114.09 KB - 201 views
[2025-12-17 16:16:13]
You can open a chart for any contract, it does not need to be listed in the actual list in the Find Symbol window. Just type in the symbol you want in the "Selected Symbol" field and select the button to open the type of chart you want. For instance, you can enter "CLZ20-NYMEX" and get the data for that contract displayed.
Just keep in mind that if you do open a chart for an older contract like that, you either need to set the "Days to Load" to something high enough to go back to when that data was active, or you need to set the "Date Range From/To" (which is easier).
