Date/Time: Wed, 25 Nov 2026 21:56:23 +0000
Compiling output chinese display issue
View Count: 351
[2025-12-17 02:17:23]
User457363 - Posts: 10
When I tried to compile a study source code with MS VS community v18 chinese edition, compiler output cannot be displayed in the building study window.
it showed some unrecognized blocks.
Please see attached screenshot.
Would you please fix this?
or I have to switch to system command window to compile?
Date Time Of Last Edit: 2025-12-17 02:19:16
image2025-12-17_10-14-19.jpg / V - Attached On 2025-12-17 02:14:47 UTC - Size: 341.98 KB - 154 views
[2025-12-17 15:19:36]
The way that is displaying is due to that window not being able to display the particular characters correctly. It is not an error and does not indicate anything incorrect with the build itself.
But, if you do want to view that information with the proper characters, then changing to building within Visual Studio itself would be a way to do this.
