Date/Time: Wed, 25 Nov 2026 21:56:22 +0000
Study Subgraph Invert NaN issue
View Count: 377
[2025-12-16 20:17:44]
User855240 - Posts: 12
Greetings,
I had a study subgraph invert based on synthetic VIX in region 3 of my chart which was working perfectly until the vertical scale started showing an "NaN" message.
Resetting the scale would not help. The vertical scale is set to, interactive scale range and scale range automatic.
Is there anyway that this issue can be fixed?
Best,
Jay
[2025-12-16 20:28:07]
You must have a situation where a "divide by zero" is occurring. You would need to find out where that is happening and then find a way to prevent it.
