Date/Time: Wed, 25 Nov 2026 21:56:24 +0000
Version 2834
View Count: 344
| [2025-12-16 13:44:51] |
| Jim_W - Posts: 23 |
Dear SC Downloaded prerelease to try out the new window features, colors etc. After I wanted to reinstall previous version long story short, I ended up being on 2834 right now. In this version when I maximize a window and then want it to snap back to the original location by clicking "restore" it will always default to the left hand side. Saving a layout first won't help. Very annoying. Am I doing something incorrectly or is this a bug? Which version would I need to default back to to circumvent this issue (in other words the version that does not offer this new window coloring, moving functionality). Thank you |
| [2025-12-16 14:57:30] |
| User719512 - Posts: 548 |
Wow, that is definitely annoying. This issue is not present in v2833.
| [2025-12-16 15:05:21] |
| Sierra_Chart Engineering - Posts: 25483 |
In this version when I maximize a window and then want it to snap back to the original location by clicking "restore" it will always default to the left hand side. Saving a layout first won't help. Very annoying. We apologize for this. We are removing this version.Follow the instructions here to go back to the previous version.: Software Download: Software Rollback Procedure Do not save the Chartbooks and there are also backup Chartbooks available. We are still working on minimize, and restore functionality. We had disabled in a release build, changes to minimize that are not done, but we had forgotten about restore. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-16 15:18:14
