Date/Time: Wed, 25 Nov 2026 21:46:18 +0000
After update 2833 FRAME-COLOUR of the individual charts HAS CHANMGED
View Count: 401
| [2025-12-15 17:04:42] |
| GlasperlenSpieler - Posts: 25 |
Dear SC, dear all, After updating to version 2833, the frame-colour of the individual charts has changed from grey to bright blue. How can I change it back to grey? Thank you in advance for your help! Date Time Of Last Edit: 2025-12-15 17:24:26
| [2025-12-15 18:21:36] |
This is part of the MDI changes we are working on. The settings that control these items is in "Global Settings >> General Settings >> GUI >> Multiple Document Interface (MDI) and Custom Title Bar Settings". The color settings are in "Global Settings >> Graphics Settings >> Window Border" and "Window Inactive Border". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-15 22:05:09] |
| Sierra_Chart Engineering - Posts: 25483 |
Refer to: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2822 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
