Date/Time: Wed, 25 Nov 2026 21:46:19 +0000
Open Chartbooks and the Chart Tabs list
View Count: 724
| [2025-12-15 16:20:53] |
| User65931 - Posts: 28 |
When two Chartbooks or more are open, the Chart Tabs lists a mix of charts from all my opened Chartbooks. How can I make the Chart Tabs show only the charts that are contained in a single Chartbook? Currently on v2813 |
| [2025-12-15 17:55:19] |
The only reason this should be occurring is if you have the option for "Window >> Window Always Visible" for those charts that are showing in both chartbooks. Refer to the following: Window, CB and CW Menus: Window Always Visible (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
