Date/Time: Wed, 25 Nov 2026 21:56:19 +0000
Get values of cumulative bid/ask in DOM?
View Count: 689
| [2025-12-14 22:47:23] |
| TopGunTrader - Posts: 313 |
Hi, I love resetting the cumulative bid/ask with hotkey however since there's not a delta column yet its of less use that it could be like Jigsaw has which shows the net buying/selling and they have delta column which can be reset at any point with hotkey too. Is there at least a study in Sierra that can give me those values so I can put a giant TEXT column of NET DELTA since last reset? Markets are fast its IMPOSSIBLE to calculate or even sometimes get an idea of which side is winning I need the real numbers. Would love cumulative bid/ask then I can calculate the total volume which I'd have in text box and delta % too. Thanks. I know SST custom studies has this but I'm not subscribing to his studies now $80+ a month. There's got to be a way to see net delta I just can't find it! |
| [2025-12-15 16:39:58] |
If you are wanting the Delta information for each price level, then the only built-in option for this would be to use the "Large Volume Trade Indicator", as it has options for the "Draw Mode" of "Based on Total Ask Bid Volume Above Threshold - Difference" and "Based on Total Ask Bid Volume Above Threshold - Diagonal Difference". To show the values, set the "Draw Volume Text" to something other than "None". You can then set the "Volume Threshold" to "1" in order to get all the data. You will then get the Ask minus Bid (Delta) displayed for each level within a bar. Refer to the following: Large Volume Trade Indicator For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-15 16:55:57] |
Hi, Yes thats great but was referring to DOM column current bid volume current ask volume get those and calculate the delta since last reset and going to display it as text right of current bar. So for example lets say NQ coming to support level 25400.00 I'll hit the hotkey to rest current bid/ask volume and then see the net total since last reset. I may reset it 5-25 times before it appears safe to buy that support area. Just to be clear once I clear current bid ask say this forms Bid Ask 1 15 53 15 35 5 Total Selling 89 Buying 35 I'd have spreadsheet study that if I can get those values do buying - selling which is 54 net selling since last refresh. I'd also show delta % which is 71.7% selling. So I refresh and may see Bid Ask 5 50 10 50 0 50 Now there is 135 net buying and 90.9% buying delta. I then may go market or put limit buy close by. That's why I want it I'm going to show a BIG text box green for positive and red negative delta. I attached Jigsaw pic and it shows why this is so critical impossible to add these all up in fast markets. |
| [2025-12-15 18:18:39] |
We understand what you are looking for. There is no direct support for this at this time. We have noted this as a Feature Request, but we can not say when we would get to any particular item. Note that you can get what you want using a Custom Study. Refer to the following: ACSIL Interface Members - Functions: sc.GetCurrentTradedAskVolumeAtPrice() https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-15 22:56:41] |
| gcUserStudies - Posts: 146 |
Please try this and see if it does what you want. It also outputs the delta value to a subgraph so you can use from other charts if needed.
| [2025-12-16 16:15:37] |
| Sébastien - Posts: 156 |
Thank you gcUserStudies for sharing this simple but useful study !
