Date/Time: Wed, 25 Nov 2026 21:46:19 +0000
Order line placement
View Count: 482
| [2025-12-12 18:44:47] |
| User449884 - Posts: 238 |
I like to have multiple DOMs side by side. However the width of the order lines make it that i have to widen my doms to accomodate for the width or the order lines. Is there a way to modify the placement of order lines, or any way to move them ? Thanks |
| [2025-12-12 22:16:44] |
You can adjust the location of the Position line by changing the following setting and the 3 below it: Chart Settings: Align Order Cancel (X) Button to Right (Chart >> Chart Settings >> Trading menu) Also, on a Trading DOM, the position and orders are highlighted in the Price Ladder, so if you do not want to view the lines, you can just use that indication. Also, refer to the following for the items to control what is displayed in a Position Line: Global Trade Settings Windows: Chart Position Line (Global Settings >> Chart Trade Settings >> General) And refer to the following for the items to control what is displayed in an Order line: Global Trade Settings Windows: Working Orders - Display (Global Settings >> Chart Trade Settings >> Working Orders) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
