Date/Time: Wed, 25 Nov 2026 21:46:20 +0000
[User Discussion] - BTC continuous contract won't enable
View Count: 440
[2025-12-12 13:51:31]
adam czuk - Posts: 28
I have the exact same issue as this user in this support thread:
BTC and ETH futures (CME) continuous contract: only getting 5 months of history
I did everything that support told them to do however my BTC continuous futures contract chart still has the [-D] at the top for disabled
again I did everything that was described in the post and issue persists. I used to have continuous contract charts for BTC but idk what changed, might've happened with an update or something. I never even mess with symbol settings anyway. I know I never opened the global symbol settings window ever until I found that support thread. Have continuous charts for other symbols, only BTC and ETH CME futures symbols affected...
[2025-12-12 14:21:39]
In the global settings window, for symbol: "BTC?##-CME" some of the settings paths say "BT?##" , it seems like they should say "BTC?##"
I tried changing that with custom settings but it did not help so changed it back to everything that was suggested in the linked thread above.
imageScreenshot (668).png / V - Attached On 2025-12-12 14:16:25 UTC - Size: 146.66 KB - 172 views
[2025-12-12 16:30:17]
You need to update to the latest release, as there was an issue with that specific symbol at one point. Follow these instructions to update:
