Date/Time: Wed, 25 Nov 2026 21:46:24 +0000
How to move my spreadsheet window
View Count: 427
| [2025-12-11 18:02:07] |
| User770314 - Posts: 8 |
Hello I would like to move my spreedsheet window on the last position but it is sock and I can't move on left or right. Ok with other wîndow |
| [2025-12-12 22:49:40] |
| Sierra_Chart Engineering - Posts: 25483 |
There is not a way to do this. In the row of tabs a spreadsheet window will show after the chart it is associated with.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-12 22:52:44
| [2025-12-13 09:38:01] |
Ok but how to associate a spreadsheet to a chart ? when I change the sheet number it doesn't change anything |
Attachment Deleted. |
| [2025-12-15 15:17:16] |
We are not understanding the question. Please give us more information on what exactly you are referring to.
| [2025-12-15 17:08:34] |
Normally the Spreadsheet windows, will always be on the right side of the MDI tabs bar. It is not possible to reorder those Spreadsheet tabs. It is not possible to move Chart window tabs between Spreadsheet window tabs or after them. But in my case and since one week, my Spreadsheet windows is in the middle of my MDI tabs. See picture please How can I reorder it ? |
| [2025-12-15 18:23:54] |
You can not reorder it. It is set to be next to the chart on which that spreadsheet was last added. So if you have that spreadsheet associated with multiple charts, it will be tied to the last chart that loaded the spreadsheet. Also, you can move tabs to the right side of the spreadsheet, you just need to move the tab to the right of the chart associated with the spreadsheet (between the chart and the spreadsheet tabs) and drop it there. It will then be put after the spreadsheet tab. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-15 19:12:41] |
Ok, so how do I link the spreadsheet to a chart? I want the spreadsheet to be positioned last, after my charts. See pic |
| [2025-12-15 19:59:02] |
We need to add a setting to control this behavior.
