Date/Time: Wed, 25 Nov 2026 21:46:21 +0000
[User Discussion] - Remote Build vs Local Build Development Environments
View Count: 559
[2025-12-11 02:30:30]
TriStar Trading - Posts: 201
I am working a project with ChatGPT, GROK, and Claude. I'm building a microstructure tape reading engine. The AI's keep running into older legacy compiler issues. ChatGPT especially. It maintains a lot of the newer call etc. are not available to my compile. What are your thoughts on this? The current iteration I am developing is as detailed as I have been as to microstructure features. Or, maybe I have let the AI run amok. If I switched VS would it be a newer environment? I have the ChatGPT questions that I have answered in its attempt to nail down the development environment constraints. Thanks! Mike
[2025-12-11 14:39:25]
User907968 - Posts: 887
The AI's keep running into older legacy compiler issues...
...If I switched VS would it be a newer environment?
You can specify the c++ version (and build tools) in local environment if that is what you mean.
I assume Claude etc is using c++20 language features and remote compiler is not supporting it, therefore you run into problems.
[2025-12-11 16:00:48]
Thanks User907968. Until now my study development has been fairly mundane so I had really no issues. I used to be familiar with the VS environment years ago so I guess here we go again. :) History might not repeat itself, but it will rhyme. ~ Twain (I think).
Date Time Of Last Edit: 2025-12-11 16:01:12
[2025-12-11 16:11:27]
Here are the remote environment specs should they be useful.
2025-12-11 10:03:41.343 | ACSIL | Chart: #1 ESZ25_FUT_CME[M] 1 Sec | Study: TriStar EnvProbe Log | TriStar EnvProbe — runtime macro dump:
2025-12-11 10:03:41.343 | ACSIL | Chart: #1 ESZ25_FUT_CME[M] 1 Sec | Study: TriStar EnvProbe Log | SC_DLL_VERSION = 2827
2025-12-11 10:03:41.343 | ACSIL | Chart: #1 ESZ25_FUT_CME[M] 1 Sec | Study: TriStar EnvProbe Log | __cplusplus = 201703L
2025-12-11 10:03:41.343 | ACSIL | Chart: #1 ESZ25_FUT_CME[M] 1 Sec | Study: TriStar EnvProbe Log | __VERSION__ = "9.3-win32 20200320"
2025-12-11 10:03:41.343 | ACSIL | Chart: #1 ESZ25_FUT_CME[M] 1 Sec | Study: TriStar EnvProbe Log | Compiler: "9.3-win32 20200320"
2025-12-11 10:03:41.343 | ACSIL | Chart: #1 ESZ25_FUT_CME[M] 1 Sec | Study: TriStar EnvProbe Log | EnvProbe complete.
