Date/Time: Wed, 25 Nov 2026 21:46:21 +0000
Changing symbol in Chartbook via Watchlist issue
View Count: 474
| [2025-12-10 21:10:07] |
| nwills - Posts: 26 |
I have a chartbook that consists of multiple charts/timeframes all for the same symbol. All charts are symbol linked via chart linking. I have an associated Watchlist on the main chart for which I have also created a control bar button to quickly switch symbols. In the first symbol I have a TPO chart in which I have merged multiple TPO profiles together but when I switch to another symbol and return to the first symbol the merges are no longer there even though I have saved the Chartbook. How can I have the TPO merges for the first symbol be saved so that when switching symbols I don't lose the merges/composite profiles? |
| [2025-12-10 22:18:11] |
There is not a way to have the merges saved when you are changing the symbol of the chart. Whenever you change the symbol, you are losing all of that information and starting over. The only way to have the merges/splits saved is to save the chartbook at that state. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
