Date/Time: Wed, 25 Nov 2026 21:46:24 +0000
limit order not fill
View Count: 345
| [2025-12-10 16:12:09] |
| User177904 - Posts: 1 |
Dear Developer, I have a question regarding manual replay simulations using SC data based on a 1-second ticker. When placing limit orders, they fail to execute. For example, a limit buy order at 2782.50 cannot be filled because the 1-second ticker lacks tick data, resulting in Bid and Ask prices that do not meet the limit order criteria. However, the lowest price on the candlestick chart would satisfy the order. My question is: in markets like ES, I believe this should be sufficient for execution. Therefore, I'm inquiring whether it's possible to implement a bar-based mode similar to automated trading, where execution is determined based on the OHLC of the candlestick. Otherwise, with only 1-second data available, precise execution of limit orders becomes impossible. |
| [2025-12-10 17:05:21] |
The account that you have posted from is expired. If you have an active account, then we need for you to post from that active account in order for us to give support. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
