Date/Time: Wed, 25 Nov 2026 21:46:24 +0000
Chart DOM VS Regular Dom Data Mismatch?
View Count: 413
| [2025-12-09 18:51:41] |
| User172061 - Posts: 36 |
Hi All, I have a Chart Dom on ES footprint mapped to MES (trading MES using ES data) and i have the same setup on a DOM. but when i look at the resting orders on the DOM vs the Chart DOM and the recent traded numbers, they just flat out dont match. I"m not sure what to do with that and how to get it to match. the DOM makes more sense as to what im seeing, and the chart dom just....doesnt? |
| [2025-12-09 20:12:29] |
One of those charts must be set to have the option for "Use as Trade Only Symbol" set to "Yes" and another one set to "No". In the chart where it is set to "No", the market depth data you are viewing is the data for the "Trade and Current Quote Symbol", whereas the other chart is for the main symbol. So these would give you two different sets of information. Refer to the following and the item above it for the "Trade and Current Quote Symbol": Chart Settings: Use as Trade Only Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
