Date/Time: Wed, 25 Nov 2026 21:46:24 +0000
[User Discussion] - How to use spreadsheet referencing 2 charts trading the same symbol
View Count: 396
[2025-12-09 17:31:43]
alphaXecution - Posts: 29
I would like to use 2 strategies using spreadsheets referencing 2 different charts. The charts are 250 trades and 1500 trades charts. I want to have one strategy on each chart. Can I refer to both charts using the same spreadsheet or do I have to add one spreadsheet study in each chart? if I have use 2 spreadsheets, will the data in column J will act independently in each spreadsheet or will it be combined in term off position and P/L?
[2025-12-09 18:33:50]
We assume that these are for different symbols, as you can not manage different strategies for the same symbol for the same trading account.
To have two different strategies for different symbols in different charts, you need to have a copy of the Spreadsheet System for Trading in each chart. You can have both charts using the same Spreadsheet File, but if you do this, then you need to ensure that each chart is using a Sheet that is specific to that chart - this is the case by default, as the Sheet that is used is based on the Chart Number.
The Column I/J information will be for that specific chart unless it is a Global item like "All Symbols Daily Net Profit/Loss".
