Date/Time: Wed, 25 Nov 2026 21:46:24 +0000
[Programming Help] - Implementing DTC Server
View Count: 477
[2025-12-09 11:45:16]
mdomans - Posts: 5
I'm working on a pass through system for trading to allow for more granular risk management.
1. Can you provide or link sample code for server?
2. Is it possible to implement server only to handle orders and have client pull market data and historical market data from Denali?
[2025-12-09 16:05:55]
We do not have any sample code. So you want to create a DTC Protocol Server that Sierra Chart will connect to, to receive the trading orders?
And then within Sierra Chart connected to that server you also want to use the Denali Exchange Data Feed for market data?
This is supported.
Date Time Of Last Edit: 2025-12-09 16:06:32
[2025-12-09 17:13:23]
mdomans - Posts: 5
Yes.
Do I need any special configuration on client side or would all be set via support flags on response to LOGON?
[2025-12-09 17:28:37]
mdomans - Posts: 5
Essentially this setup as in image provided
imageScreenshot 2025-12-09 at 18.27.08.png / V - Attached On 2025-12-09 17:27:32 UTC - Size: 160.7 KB - 143 views
