Date/Time: Wed, 25 Nov 2026 21:46:23 +0000
Display Study Subgraph Above/Below Bar as Text rendered vertically?
View Count: 495
| [2025-12-09 11:06:03] |
| tallcupofcoffee - Posts: 15 |
I found some very old threads that asked for the ability to pivot rendered text by 90 degrees (to display vertically) but nothing recent. Is this now supported? I'm unable to find a Setting or Drawstyle that configures this. Thanks. |
| [2025-12-10 16:45:23] |
This is still not supported. We have noted it as a Feature Request, but we can not say when we would get to any particular request.
| [2025-12-11 18:41:29] |
| User719512 - Posts: 548 |
Curious @tallcupofcoffee, how would you use this? Would you ever use multiple signals with vertical text that could fire on the same bar?
| [2025-12-11 21:43:53] |
I have a few charts where I both want to see delta numbers as well as have enough of the price action on the screen to discern the movement. As is, I have to resort to a very large window to do so. |
| [2025-12-11 22:12:43] |
Maybe there is a solution for this already... Care to share a screenshot or a mock-up of the desired chart? |
| [2025-12-12 14:38:15] |
This is the basic layout. Two images, one with the price intervals scrunched and the other to show what's there. If I could render the delta text vertically, I could show so much more price action in the window. https://www.sierrachart.com/image.php?Image=1765549971607.png https://www.sierrachart.com/image.php?Image=1765550151150.png |
