Date/Time: Wed, 25 Nov 2026 21:46:03 +0000
Problems moving settings from original Sierra to new install in different directory.
View Count: 362
| [2025-12-08 17:41:26] |
| TopGunTrader - Posts: 313 |
Hi, I am trading prop firms along with my main account and setup new Sierra install and different directory to do this. I followed this page's instructions but doesn't appear to be working control bars different and hotkeys not configured so doing something wrong. Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Chris Donnell Date Time Of Last Edit: 2025-12-08 19:37:44
| [2025-12-08 18:02:52] |
That is the correct page for the information. Particularly Step #5 in this section: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Make sure you have copied all the correct files, including "KeyboardShortcuts4.config". And also make sure that Sierra Chart is not running in either instance when you are doing the copying and pasting of the files. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
