Date/Time: Wed, 25 Nov 2026 21:46:01 +0000
Error message for order entry reoccuring
View Count: 414
[2025-12-08 17:15:06]
User415279 - Posts: 27
I have the following on the chart DOM settings:
Left click on buy column above last, buy stop
right click on buy column above last, ignore input
left click on sell column above/equal last, sell limit
right click on sell column above/equal last, ignore input
left click on buy column below/equal last, buy limit
right cli8ck on buy column below/equal last, ignore input
left click on sell column belo0w last, sell stop
right click on sell column below last, ignore input
The problem I keep having is that I go to place a buy stop above the last trade price to get long while price is moving to and through the said price. I click in for a buy stop, then it seems as if it is registering the price once it hits the server as equal to or at the exact price (which should be a limit), then kicks back an error message saying "I must place stop above last traded price", which I did, but by the time it registered price was at the initial entry price (considering it equal), then doesn't fill me and gives me the error message. How can I avoid getting this error message? Is there a way to allow for buy stops or sell stops to be filled even if price is equal to entry for when this happens so I don't get an error message? Or, what order type would be recommended to get in with a stop aggressively, but allow it to function at entry price if equal by the time it routes?
imageIMG_2744.jpg / V - Attached On 2025-12-08 17:05:13 UTC - Size: 4.67 MB - 192 views
[2025-12-08 17:46:10]
Within Sierra Chart, there is the following option:
Global Trade Settings Windows: Reject Stop Orders That Will Immediately Fill (Global Settings >> Chart Trade Settings >> General >> Order Entry)
So make sure this is set to "No" so Sierra Chart is not stopping the order from being sent. But, as noted in that documentation, you will probably still get an error from your trading service, in which case you would need to talk to them if there is anything you can do.
[2025-12-08 19:45:33]
Also look at this order type:
Order Types: Triggered Limit
[2025-12-08 20:06:06]
Okay, I will take a look.
Thank you!
