Date/Time: Wed, 25 Nov 2026 22:08:05 +0000
Use Large Volume Number Formatting - Numbers Bars Calculated
View Count: 383
[2025-12-08 16:12:44]
User581488 - Posts: 2
How can I get my numbers at the bottom to use large number formatting? I have set value format to large integer with suffix. Cant see the setting: "Use Large Volume Number Formatting"
imageScreenshot 2025-12-08 161213.png / V - Attached On 2025-12-08 16:12:24 UTC - Size: 220.75 KB - 200 views
[2025-12-08 17:15:39]
What you did is the correct option to have the Numbers Bars Calculated Values use the Large Number Formatting.
But, the formatting only occurs when you have values of 10000 and greater. The image you provided shows values less than 10000 so this would not apply to those numbers.
[2026-01-04 21:21:31]
User763335 - Posts: 133
Hello John,
can we have the option to enable "large number formatting", for numbers greater than 1000?
thanks
[2026-01-05 16:15:45]
We have noted this as a Feature Request. We can not say when we would get to any particular request.
