Date/Time: Wed, 25 Nov 2026 21:46:09 +0000
Latest Release
View Count: 819
[2025-12-08 11:12:21]
Jim_W - Posts: 23
Hi John,
Can you please confirm if the latest release v2813 (released just now) offers the feature to color the main window? Or that is not yet functional but will be in the next release?
I can change color for the Main Window Background(under Global Graphics Settings), but when setting/changing the color for the following: Window Title bar, Inactive Window Title bar, Window Title Bar text or for all these newly added properties....nothing happens. Just want to know if the issue is at my end or feature is perhaps only partially live.
[2025-12-08 11:30:58]
DFromeaux - Posts: 29
Check which version you have installed by going here: Help -> About.
I updated earlier today and ended up with version 2812 ( I’m on Mac, so I’m using the ARM build ).
The new features are on version 2813 and higher ( as you know )!
Date Time Of Last Edit: 2025-12-08 11:31:38
[2025-12-08 12:04:18]
Jim_W - Posts: 23
Yes thank you! I am on the latest release, v2813.
[2025-12-08 12:20:07]
Jim_W - Posts: 23
It is weird as the Window Title bar color is set to a deep blue color by default but I still have the original pre release sierrachart white/grey color and unable to change it. Is something need to be set under the GUI to active these maybe? Have not found any settings. Anyway awaiting response from John.
[2025-12-08 14:49:43]
Regarding post #1, the functionality you require is supported in prerelease version 2825.
Update instructions:
And those settings only apply to the MDI child windows. They do not apply to the main title bar of the program or to detached windows, or any other window.
Date Time Of Last Edit: 2025-12-08 14:50:36
[2025-12-08 15:28:00]
User690628 - Posts: 18
Will the main title bar and other windows be switched to this functionality later as well for consistency? Thank you.
[2025-12-08 15:31:53]
Not anytime soon. That is very difficult to accomplish and has negative side effects. Because it would require that we implement our own menus. And scrollbars.
For example it would cause Sierra Chart not to be compatible with screen readers.
So probably this would never happen. At least it is never planned.
Date Time Of Last Edit: 2025-12-08 15:32:20
