Date/Time: Wed, 25 Nov 2026 21:46:03 +0000
Can't connect to IBKR data feed
View Count: 351
| [2025-12-08 01:46:24] |
| mokshaman - Posts: 1 |
I purchased a month of package 10 that is supposed to allow for IB data feed, but even though I've followed the instructions, I keep getting "not enabled on package" when I try to connect. What to do? Lowell Blum user: mokshaman |
| [2025-12-08 16:28:26] |
At the time that you posted this, you were not actually on Package 10, you were still on the Trial. You are currently on Package 10, and you should be able to connect to Interactive Brokers. The instructions to connect are here: Interactive Brokers Trading Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
