Date/Time: Wed, 25 Nov 2026 21:46:09 +0000
Time zone of timestamps in saved data files?
View Count: 564
[2025-12-07 20:11:55]
Chad - Posts: 247
Hi SCE, quick question:
If the Time Zone setting (in Symbol Settings) for any given symbol is, say, New York (-5 EST/-4 EDT) but Global Settings->Time Zone Settings is Chicago (-6 CST) and the Chart windows used to request/load/save data for a market (both tick and depth data) are configured to use the Global TZ, will the data be saved with timestamps per Global TZ, not per Sym Settings?
[2025-12-07 21:01:19]
All permanent storage, of any timestamp anywhere in Sierra Chart, whether it is an Intraday data file, or within a Chartbook is always in UTC.
Date Time Of Last Edit: 2025-12-07 21:01:32
[2025-12-08 16:15:18]
Also, the Time Zone that is defined in the Symbol Settings is only there to define the Session Times that are set in the Symbol Settings. That Time Zone is not actually used for a chart.
