Date/Time: Wed, 25 Nov 2026 21:46:20 +0000
Historical Market Depth calculated for visible chart only
View Count: 381
| [2025-12-06 09:39:10] |
| Eranox - Posts: 41 |
Hi there, I’m interested in knowing if there’s a way to calculate Historical Market Depth levels only on the visible part of the chart, instead of all levels being set in the Maximum Levels to Display option. I’ve already set Determine Min and Max Levels from All Bars or Visible Bars on Visible Bars, but the color of the levels is still calculated based on the Maximum Levels to Display option. I’d like that colors change when I zoom in or zoom out on the price scale. Thanks for your help! Date Time Of Last Edit: 2025-12-06 09:40:06
| [2025-12-08 15:28:21] |
We are not certain if we are understanding the request. We think you are asking to not only limit the determination of the Maximum and Minimum from the horizontal Visible Bars, but also in the Vertical scale, so it would not only limit it by the visible bars, but also by the visible prices. If this is what you are asking for, then there is not a way to do this in the system at this time. We will note this as a Feature Request, but we can not say when we would get to any particular item. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-08 20:02:29] |
Exactly Thanks |
