Date/Time: Wed, 25 Nov 2026 21:36:02 +0000
DOM Graphics
View Count: 476
[2025-12-05 17:23:47]
John Ferretti - Posts: 5
2 options for changing text color and chart background. either global settings or just the single chart. so when i have my DOM open and want to change font and background color the color doesn't work when i click 'apply." i dont want to use global graphics obviously im just changing my DOM chart. What do i do? The DOM graphics is not working its not changing colors.
[2025-12-05 18:43:47]
You need to select "Chart >> Graphics Settings" on the Trading DOM itself and then uncheck the box for "Use Global Graphics Settings Instead of These Settings". Then change what you want in that window to modify how the Trading DOM appears.
Refer to the following:
Graphics Settings: Use Global Graphics Settings Instead of These Settings
