Date/Time: Wed, 25 Nov 2026 21:35:51 +0000
Changing data to Rithmic
View Count: 457
| [2025-12-05 17:15:35] |
| LarryB - Posts: 4 |
I am trying to change my data feed to Rithmic from Teton, I need to Sierra to allow this so Amp Futures can set it up. I put ticket in at 8:18 AM 12/05/2025 Larry Barbour lkbarbour@comcast.net |
| [2025-12-05 18:41:47] |
There is nothing we need to do on our end for this. It is all controlled by you (and AMP). To setup Sierra Chart to connect to Rithmic, follow these instructions: Rithmic Trading Platform Service: Setup Instructions You refer to "data feed". Right now, you are setup to get data from our Denali Exchange Data Feed, as you have the following exchange active: - Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for Non-Professional Trading Accounts If you do not want to use this data and instead want to get the data from Rithmic (which we do not recommend), then you need to set "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support For Sierra Chart Data Feeds" to "No". Or, if you want to use the Denali data until the end of the month, then leave "Allow Support For Sierra Chart Data Feeds" as "Yes" and just deactivate the exchange you have active at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges Since you have already paid for this data, you will get it through the end of the current month and then you will be using the Rithmic data after that. As to our position on the Rithmic data, refer to the following: Rithmic Trading Platform Service: Rithmic Support Policy For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-05 18:51:26] |
| User135243 - Posts: 337 |
if you've an account with Rithmic-data, you just have to create a connection (nothing to allow), but keep in mind, this is not the best solution
