Date/Time: Tue, 17 Nov 2026 18:08:55 +0000
CL (Crude Oil) on Delayed Feed
View Count: 457
| [2025-12-05 13:23:37] |
| bobstone249 - Posts: 61 |
Hi, I've had an account with SC for a few years now. Recently set up an additional instance/log-in for SC to test and trade CL. I'm trading ES (S&P500) successfully in the original instance of SC. I have aligned all the global settings between the 2 instances of SC. I have even copied the chartbook into the original session of SC (where I successfully trade ES) to test it in an environment where I know I don't have a delayed feed. The VWAP chart and other charts are still showing a delayed feed. Can you please help. Symbols - ES Micros MESZ25_FUT_CME - CL Micros MCLF26_FUT_CME Current Service Package is 11 Denali data, Teton order routing, Dorman/Stage 5 account Many thanks Rob |
| [2025-12-05 14:23:28] |
| User135243 - Posts: 334 |
I guess you don't have Nymex realtime data, that could be the problem with delayed data
| [2025-12-05 15:28:11] |
| John - SC Support - Posts: 48555 |
As User135243 points out, you do not have the NYMEX exchange setup, so you are not going to get the real-time data for CL, or for any product traded outside of the CME exchange, which is the only exchange you have active to get real-time data. You can add/change your exchange selections at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-05 19:09:50
| [2025-12-05 18:18:09] |
| User584084 - Posts: 347 |
NYMEX is required for real-time CL data. COMEX is for the metals.
| [2025-12-05 19:09:37] |
Sorry for that - yes it should be NYMEX for CL. We updated our previous post. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-10 12:15:05] |
Apologies John and all others who kindly responded, I should have noticed this. Thanks
