Date/Time: Wed, 25 Nov 2026 21:35:56 +0000
Footprint. Delta ladder profile
View Count: 438
| [2025-12-05 11:15:22] |
| dikii_tapok - Posts: 8 |
Dear support team, Hope you are well. New user hear. I am currently in process of moving from MW to Sierra and try to recreate my workspace. Could you please advise if there are any methods to recreate Bid Ask Delta Ladder profile? Please see attached screenshots with MW reference point of what I try to achieve regarding bid ask coloring and what I have in Sierra as of now. I think its possible, but it does not 'click' for me on how to achieve it. Both screenshots are made for first 5 minutes bar open 4 Dec 2025 Sierra.png MW.png Kind regards, Vitalii Date Time Of Last Edit: 2025-12-05 11:15:39
| Attachment Deleted. |
| [2025-12-05 15:19:23] |
We have no idea what MW is doing, so we can not give any specific advice in this regard. What exactly are you trying to accomplish? Do not think in terms of "how MW does it", just give us the core of what it is you want to see. We will then point you in the right direction from there. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-05 17:41:36] |
I guess this is most proper description I have found. https://help.exocharts.com/hc/en-us/articles/360018309017-Delta-Ladder-Profile basically this type of background visualization for bid ask candle sorry for external ref |
| [2025-12-05 19:03:58] |
That reference doesn't tell us anything. It states "On the left side, colored in fading red, sells are displayed. On the right side, colored in fading blue, buys are displayed." You have the Sells and Buys displayed and you have at least something of the profile displayed for each side, which is what the reference states. You must have something specific you are looking for, as you state that you are not able to get it setup yet in Sierra Chart. Exactly what is it you are looking for? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
