Date/Time: Tue, 17 Nov 2026 18:09:01 +0000
SC2813 downloads data while disconnected
View Count: 345
| [2025-12-04 13:25:57] |
| User512353 - Posts: 198 |
SC2813 with IBKR Gateway During overnight session I use SC to backtest a trading system on older data. For this I explicitly disconnect SC, i.e. File >> Disconnect. This should prevent SC from downloading any market data for any symbol. However, I upgraded SC from 2812 to 2813, and now SC is downloading market stream data for the symbol I am testing, while being disconnected. This should not occur. |
| [2025-12-04 15:33:47] |
| Sierra_Chart Engineering - Posts: 25432 |
Historical data will be downloaded for symbols supported by Sierra Chart historical data servers, even when disconnected. But no real-time or streaming delayed data will be received.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-04 18:25:05
