Date/Time: Wed, 25 Nov 2026 21:36:36 +0000
how can i shrik the dom and not cause crunching?
View Count: 295
| [2025-12-03 15:16:16] |
| ldepadey - Posts: 73 |
hi, please find screenshot attached, i'm trying to make the dom lower in hight without everything crunching..? thanks
Date Time Of Last Edit: 2025-12-03 15:17:27
| [2025-12-03 15:23:02] |
The items are going to "crunch" as you make those kind of changes. But, you can aggregate the data in the DOM by using the following settings, so you can then not have the data overlapping: Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu) Chart Settings: Apply Combine Increment in Ticks to Other Market Data Columns (Chart >> Chart Settings >> Market Depth menu) For the Volume by Price study, if you want to do the same thing, you would change the "Ticks per Volume Bar". Refer to the following: Volume By Price Study: Ticks Per Volume Bar There is not a way to have these things occur automatically, you do need to change these manually based on how you have the DOM setup. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
