Date/Time: Wed, 25 Nov 2026 21:35:50 +0000
Multiple Selection Boxes for Draw VBP
View Count: 295
| [2025-12-03 02:36:04] |
| FelixAndres090519 - Posts: 16 |
I've set my VBP studies to "Start date-time to end" because the default Draw VBP was constatly detaching from last price bar. But, now I have 2 selection boxes for each VBP study. See image for reference. I don't mind having the Draw VBP study set to the deafult "Start date-time to end date-time" as long as it stays put and I dont have to re-extend it to keep the data updating. Any way around this? |
| [2025-12-03 15:04:25] |
We are not quite understanding the situation and the particular issue, particularly around having multiple selection boxes. To begin with, the Drawn Volume by Price is always going to set a Start Date-Time and an End Date-Time. This is the purpose of this feature, to define a specific time period over which the profile is drawn. There is not a way to have it automatically use the option of "From Start Date-Time to End". You can change this after the drawing is done, but you can not set it up this way. With regards to the multiple selections, this implies that there are 4 drawings in the area where you are trying to select (per your image). Are you saying that you should not have 4 items in there? Check the "Analysis >> Studies" window and see if there are, in fact, 4 volume profiles set to display. You will need to figure out why this is occurring, we do not know what exactly you are doing that would cause this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
