Date/Time: Wed, 25 Nov 2026 21:35:52 +0000
TIME OF CANDLE NOT SHOWING
View Count: 378
[2025-12-03 00:23:34]
Gwekking - Posts: 1
On my ES Footprint chart, the time scale at the bottom has disappeared.
I am using Numbers Bars with Numbers Bars Calculated Values underneath, and for some reason the candle times are no longer visible
It seems the footprint chart specifically is preventing the time scale from displaying. (On 6e everything is normal and on ES no time)
Could you please help me identify what setting or interaction might be causing this?
Thank you!
Private File
Private File
[2025-12-03 04:10:08]
Check the color settings:
Graphics Settings
The: Chart Time Scale Text Color
Date Time Of Last Edit: 2025-12-03 04:10:16
