Date/Time: Wed, 25 Nov 2026 21:35:46 +0000
Disable Average Price on DOM + Display Individual Entry Prices + Flatten Hotkeys
View Count: 538
[2025-12-02 19:54:35]
User941854 - Posts: 9
I trade only from the DOM with Level II CME data.
I need to disable the Position Average Price display on the DOM and instead show each original entry price. For example, if I am long 4 ES at 5000, another 4 at 5013, and 4 at 5017, I want to see each entry price, not the combined average. Is there any way to hide the average price on the DOM or use a study that marks individual fill prices directly on the DOM ladder?
Additionally, none of the Flatten hotkey commands work for me, even though I can assign other keyboard shortcuts (like recentering). Is there a specific requirement or setting needed for Flatten hotkeys to function?
Thanks kindly
[2025-12-02 20:41:27]
Sierra Chart only shows the Position Average Price. There is no option to display the individual positions.
Most likely, the option for "Trade >> Trading Keyboard Shortcuts Enabled" is not enabled. Make sure there is a checkmark next to this item. If not, you should get an error message in your Message Log when you try to use a Flatten keyboard shortcut telling you that you need to enable this option. Refer to the following:
Trade Menu: Trading Keyboard Shortcuts Enabled (Trade menu)
[2025-12-04 00:43:38]
I appreciate your responses!
1. is it possible to disable the average price showing altogether then? okay--so no study exists that could help solve this (in terms of showing each and every position)?
2. I have enabled "Trade >> Trading Keyboard Shortcuts Enabled" and followed this path to no avail still: Global Settings >> Customize Keyboard Shortcuts >> Trading Keyboard Shortcuts (note, the log states: Shortcuts Enabled'. *
2025-12-03 18:30:08.544 | Replay 1.00X: ESZ25_FUT_CME[M] #1 | Enable trading keyboard shortcuts with 'Trade >> Trading Keyboard Shortcuts Enabled'. *)
thanks
[2025-12-04 14:36:07]
1. Refer to the following:
Global Trade Settings Windows: Display Average Price (Global Settings >> Chart Trade Settings >> General >> Trade Position Line)
There are no built-in studies that will show you the individual positions. But, you could do this with a custom study by placing a drawing at each position based on the information for the orders. Refer to the following:
Using Drawing Tools From an Advanced Custom Study
Automated Trading From an Advanced Custom Study
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
2. The fact that you are getting that statement in the log means that "Trade >> Trading Keyboard Shortcuts Enabled" is not enabled. It is telling you that you need to enable it. There needs to be a checkmark next to the option.
Keep in mind that this option in the menu is per chart, so you need to ensure you have the specific chart selected from which you want to use the keyboard shortcuts (chart #1 according to the log information) and then enable the option.
