Date/Time: Thu, 26 Nov 2026 03:31:18 +0000
US Equities - Display Candles When Symbol is HALTED
View Count: 525
[2025-12-02 19:24:49]
GeeMan - Posts: 11
I was unable to find any information regarding Halt's on the forum.
How can SC Print / Show the minutes where a symbol is halted?
I want to see some kind of indication that the stock was halted....or not even halted, just a token to indicate no data was recived for those 5 / 10 minutes.
I have attached an image to illustrate.
Thank you
imageWINWORD_FVHFoxsfOz.png / V - Attached On 2025-12-02 19:24:32 UTC - Size: 77.46 KB - 220 views
[2025-12-02 20:21:35]
Refer to the following and the option just above it:
Chart Settings: Include Columns With No Data (Chart >> Chart Settings >> Bar Period >> Chart Bar Settings menu)
[2026-03-11 14:28:56]
GeeMan - Posts: 11
Works great, thanks.
(Image posted for anyone wanting to do the same)
imageSierraChart_64_nUGvNvgn1a.png / V - Attached On 2026-03-11 14:26:33 UTC - Size: 10.19 KB - 140 views
